TwinTurbo.NET: Nissan 300ZX forum - so with the screw all the way in and the connector
Subject so with the screw all the way in and the connector
Posted by inf on September 04, 2013 at 3:42 PM
  This message has been viewed 191 times.
In Reply To Re: hmm.. posted by Tuner_Dev on September 04, 2013 at 01:54 AM
Message disconnected it was at 900rpm? It should be like 500-600rpm with it all the way in. Have you tested compression? An easier way is a combustion leak tester you use with the radiator to check for gases in the cooling system. Takes 2 minutes...
